Address Locator question
4114
10
01-22-2014 10:36 AM
ChadFoster
10.1 SP1
We have an address locator that is referencing address points layer located in SDE.  We are also publishing this address locator for use in Flex Viewers as a geocoding service.
If we add address points in SDE, does the address locator update to reference the new address points?
I have tried to use the Rebuild feature in the address locator and have tried to stop and restart the geocode service with no success.
Can someone tell me the proper workflow to make sure that the address locators are up to date?
Chad
BradNiemand
We have a script shared on ArcGIS.com that can be used to automate this process.  See the link below.
https://www.arcgis.com/home/item.html?id=54e8aab14f6e4c61b65b9dd9ab451503
