Address Inspector
2899
10
11-18-2011 03:38 AM
NicholasBarger
I am having a problem with the address inspector with ArcGIS Descktop 10 SP 3.  In previous versions the address inspector tool would return a number along with the street name and municipality.  Now all I get is the street name and municipality.
I recreated an address locator in a FGDB but nothing seems to fix this tool.  Has the functionality changed with the tool?
Again this tool worked properly in ArcGIS 9.3.1 and I believe it did in the early versions of ArcGIS 10.
I'm using the new Dual Range geocoder.  Our file structure for our streets has not changed.  We have left_from, left_to, right_from, right_to fields in the data.  We also have an interval field.
***It appears this might be a bug with SP3 based on another post about reverse geocoding that I recently found.
JeffWard
Honored Contributor
The 10 geocode engine still plots points on the chord of a true curve instead of along the curve.  Any idea when this will be fixed?
Jeff Ward
Summit County, Utah
