Add a hyphen before the last 3 characters of variable length string
8892
7
04-24-2015 05:32 AM
LukeSnyder
Hi All. I'm looking for some VBScript help (or Python) to add a hyphen before the last 3 characters of variable length string. I can manage with fixed length strings, but not variable ones. 12345 = 12-345 and 123456 = 123-456.
Thanks in advance.
Luke
DanPatterson_Retired
got to love slicing  (EDIT  oooops Sorry Vince ... was playing and didn't see you had posted already)
>>> a = '123456'
>>> out = a[:len(a)-3]+'-'+a[len(a)-3:]
>>> out
'123-456'
>>> a = '12345'
>>> out
'12-345'
VinceAngelo
Esri Esteemed Contributor
No matter the language, the task is the same:
  1. Compute string length
  2. Create new string composed of:
    1. substring(pos 1 to (len-3))
    2. hyphen
    3. substring(pos len-2 to len)
The syntax is different in each language, as well as the radix of the first character (0 or 1) and the exact invocation of the substring function.
- V
>>> a = '123456'
>>> out
'123-456'
>>> a = '12345'
>>> out
'12-345'
VinceAngelo
No worries.  I often work with larger strings, which are O(N) in the length function, so I usually capture length once, vice embeding it twice. Yes, an optimizer might pick that up, but I like to pitch softly at optimizers.
- V
LukeSnyder
Thanks guys!
TimWitt2
Don't forget to mark the post with the correct answer as correct
TedKowal
Honored Contributor
VBSCRIPT:
dim a as string
a = "MyFavoriteString123"
a = Left(a, Len(a) - 3) & "-" & Right(a, 3)
LukeSnyder
Thanks Ted. I'm still learning...and always will be of course. I like this approach.
