ACAD format missing with 10.2.2?
12336
12
06-04-2014 06:10 AM
GregAnspach
Maybe I'm blind but I can't find the AutoCad dwg/dxf reader anywhere after I updated ArcGIS to 10.2.2 along with Data Interop to 10.2.2.
Now when I add an Interoperability Connection in Catalog, it wants to use the 'Esri Mapping Specification for CAD (MSC)' format, which doesn't bring over any geometry.    If I go into the Spatial ETL Tool and add a Reader, it will find the 'Autodesk AutoCAD DWG/DXF' reader but that is the only place it is listed.  I really need it available for the other options such as quick import and Interoperability Connections.
Anyone else seeing this issue?
BruceHarold
Esri Frequent Contributor
Hi
We are still looking into this, in the meantime I attach a 10.2.2 Toolbox with ACAD reader and writer, you can update the reader and writer after copying into your own tools, then they can point to your own data.
Regards
BruceHarold
Hi
This issue is fixed in ArcGIS 10.3.1, sorry for the delay.
Regards
roufbaba
Thank you ESRI
