260cm High by 400cm Width Base Map! Help Needed!
978
09-09-2012 12:37 AM
PaulCureton
I have been trying to rescale the ESRI World Physical Map to fit 260cm High by 400cm Width. First, is this actually possible? And if possible, what methods should I employ to do so. Additional data and layers have been added to the map.
I have tried adjusting page to specification and clicking the scale to page icon in print and document settings.
When exporting the pdf has blank data lines across the map and it will not create the custom page size I specified.
Any help would be appreciated, I am using ArcMap 10.1, i5 processor, 8gb Ram, good graphics card.
Any advice would be appreciated!
Paul
