Prevent the Default version from being directly edited, only allow Post operations to update the Protected Default version
2317
07-03-2024 10:12 AM
Status: Open
DrewDowling
Currently, editors with an Admin user role or Version Admin role in Portal can edit the Default version directly in ArcGIS Pro even when it is Protected.
I, and many users I have worked with over the years, find it too easy to accidentally start editing Default instead of first switching to a version. This is potentially very dangerous since there is no Undo editing Default using branch versioning.
Adding the ability to lock the Default version from direct edits would prevent this. Only Rec and Post operations will be allowed to update the default version. This would help enforce data integrity workflows and tools, such as the use of the Version difference tool.
4 Comments
BrittanyBurson
+1 - are there any other strategies for achieving this?
RyanBohan
As we transition to branch versioning, our preferred approach is for teams to create and manage their own versions, then perform reconcile and post operations to the default version. Since teams are most familiar with their own data, they are best positioned to resolve any conflicts that may arise.
  • To perform reconcile and post operations, one or two team members need to be assigned the Version Management (VM) role. Ideally, two users per team will hold this role to ensure coverage during absences.
  • However, this setup introduces a potential loophole: users with the VM role can directly edit the default version. This could prompt more team members to request VM access in order to “work faster,” effectively bypassing the intended versioning workflow.
As a safeguard, we’re considering restricting who can create versions and perform reconcile and post operations. While this would help maintain the integrity of the default version, it could also slow down workflows and place added responsibility on a small group of trusted users. These users may not be subject matter experts in the data they’re managing, which could lead to additional back-and-forth with the teams that originally created the data.
We’d appreciate any insights or experiences from others who have implemented similar workflows. How are you balancing control and flexibility in a multi-team environment?
James_Blouin
@DrewDowling@BrittanyBurson@RyanBohan  - I have developed an ArcGIS Pro add-in that attempts to alert and prevent certain edits when users have features/tables pointing to the branch Default version:
Default Version Guard - ArcGIS Pro SDK add-in - Esri Community
AlexisHandelman
@DrewDowling@RyanBohan  @BrittanyBurson@James_Blouin  I'm not sure how this went under the radar for so long. I learned this from an Esri employee at the user conference last week. I have not actually implemented this yet or tried it, but it is supposed to work to prevents edits to DEFAULT, but still allow rec/post to DEFAULT.
You can use a constraint Attribute Rule (it will need to be applied to each feature class).
if (gdbVersion($feature) == "sde.DEFAULT")
    return false;
return true;
