“Personal ArcSDE” connection restrictions should be based on the number of users, not the number of connections.
2204
05-02-2018 07:49 AM
Status: Open
AZendel
By "Personal ArcSDE" (PSDE), I mean the ArcSDE that runs on SQL Server Express is included for free with ArcGIS Desktop "Advanced" (formerly "ArcInfo").  I have countless use cases where I need SQL access to my GIS data. In the past, I’ve often used Personal (Access) Geodatabases when these needs have arisen, but that option isn’t available with ArcGIS Pro. Consequently, Personal GBD’s have one foot in the grave.  At other times, I’m working more data than PGDBs/Access can handle gracefully. In these situations, I rely on Personal SDE for my workflows and analytic projects.
I understand why ESRI set up three tiers SDE databases (Personal, Workgroup, Enterprise).  If a few users want to connect to the same database, and especially edit that database, then I think it’s reasonable for them pay more for that functionality by purchasing a “workgroup” license. Fair enough. But I am frequently being denied more connections to the Personal SDE server installed on my local machine when I’m multitasking and have a few ArcGIS Desktop products open.  As an example, I feel that I should be able to:
  • edit one PSDE feature class in one ArcMap/Pro window
  • work on a lay out with PSDE data in another
  • run one or more long-running geoprocessing scripts
It’s frustrating to open an MXD or Pro project and see a long list of red exclamation marks in the table of contents caused by the inability to connect to my database because ArcCatalog happened to be open at the same time.  We pay a handsome sum of money for ArcGIS Desktop “Advanced” and my productivity should not be hampered by these over-reaching restrictions. Again, I think it’s totally reasonable for ESRI to limit the number of users or the number of different machines with respect to PSDE database connections.  I also think it’d be fair for ESRI to deny PSDE connections from any machine running any ArcGIS Server roles (i.e., prevent people from using PSDE database to run ArcGIS server applications). That is not a “personal” use of the software. However, if I (one individual) want to connect the PSDE database on my machine, then I should be allotted a good number of more connections. This situation is amplified by having no other SQL access to my data once ArcMap is gone and the personal (Access) geodatabases are history. It's also complicated by ESRI's seeming resistance to provide an ODBC driver for the file geodatabase.
2 Comments
AZendel
Update, it looks like Personal ArcSDE databases are now called "Desktop Geodatabases". Even still, 1 user should be able to make more than just 2 or 3 connections.
deleted-user-ya5VfkkOfE1F
I installed this on my local computer and found it very useful especially when you're the only GIS person in the office and not wanting to spend a ton of dough on overblown (but useful) software products such as ArcGis Server. I was happy and being a small local government office we didn't want to and really couldn't justify spending thousands of $ at the time
. Not being able to connect a .dbo database with ArcGis Pro not only prolongs the process of trying to learn the ArcGis Pro experience but also creates animosity between the user and the software that is trying to be utilized. A more positive effect would be allowing software types (like ArcGis Server for Desktop) that previously you have given to your customer in the past, and now with that product being able to be utilized with the newer software types (ArcGis Pro) that are currently given to the customer but updated to replace the software currently being used (ArcMap) for main desktop purposes. My take on the message to me from Esri on this is they are just going to kill ArcGis Server for Desktop and make the user deal with it on their own terms and figure it out for themselves. Not only do they create more work for me when I think I've found something very useful, but in the end it's only a scheme created by marketing a product that's ever changing and in about ten years will be recreated to keep the customer buying slightly more useful products that seem slightly more revolutionary but always greatly more expensive. My take
