arcpy.Describe differentiate between fully versioned and move-to-base
833
07-09-2014 01:59 PM
Status: Closed
SteveSalas
arcpy.Describe returns the dataset property isVersioned as boolean - the described dataset could be either fully versioned or move-to-base and there is no way to determine which, other than to open the property sheet of each table or feature class using ArcCatalog.  Might need to create a property with a different name to avoid breaking scripts that currently use isVersioned and expect a True/False return.
1 Comment
KoryKramer
Status changed to: Closed
This is a duplicate of https://community.esri.com/t5/arcgis-pro-ideas/arcpy-describe-differentiate-between-fully/idi-p/9644... Please visit that open idea to add your kudos and comment.
Thank you!
