Witch Magic, Snake Oil Medicine, and Spatial Index Tuning: The Geography Version
1917
12-24-2015 12:14 PM
ThomasColson
1 0 1,917
In response to https://community.esri.com/migration-blogpost/54807
which adds some bling and zing to your SDE database, I've gotten a few comments regarding doing the same type of tuning with the Geography Storage type. Easy Cheesy, just note that this alteration simply replaces geometry with geography, and removes the bounding box from the index creation. Happy tuning!
--ORIGINAL SQL CODE FROM
--http://stackoverflow.com/users/2250424/greengeo
--MODIFIFIED TO INCLUDE SPATIAL INDEX HELP OUTPUT
--IN TABLE
  --LOOK FOR THE EXCLAMATION POINTS IN THIS CODE
  --THERE ARE SEVERAL USER-SUPPLIED VARIABLES THAT MUST
  --BE INPUT FOR THIS SP TO WORK
USE   [GPS_COLLAR]
GO
ALTER PROCEDURE dbo.sp_tune_spatial_index
  @tabnm VARCHAR(MAX), -- This parameter stores the name of the spatial table for which you are tuning the index
  @idxnm VARCHAR(MAX), -- This parameter stores the name of the spatial index of the named table
  @min_cells_per_obj INT, -- Minimum Cells Per Object to test on. Suggested to start at 2.
  @max_cells_per_obj INT, -- Maximum Cells Per Object to test on.
  /* The test requires two geography instances to use in test query 1 and 2.
  The first one should cover the area of default extent. The second should
  cover an area roughly the size of the area shown when zoomed in, panning
  around. It is required that the variable store a string that will create
  the geography instance since this will be done within the procedure and
  cannot be a variable of type: GEOGRAPHY. The SRID of these instances must
  match that of the table you are testing. */
  @testgeom1 VARCHAR(MAX), -- This parameter stores the first geography instance creation string that will be used in the test
  @testgeom2 VARCHAR(MAX) -- This parameter stores the second geography instance creation string that will be used in the test
AS
SET NOCOUNT ON;
/* Prior to running this procedure, two tables are required. These tables are
  created here to prepare for running the procedure. */
PRINT 'Checking for required tables...'
IF EXISTS(SELECT 1 FROM sysobjects WHERE name IN ('cell_opt_perm', 'spat_idx_test_result'))
  BEGIN
  PRINT '... The "cell_opt_perm" and "spat_idx_test_result" tables exist.'
  END
ELSE
BEGIN
  PRINT '... Creating "cell_opt_perm" and "spat_idx_test_result" tables.'
  CREATE TABLE cell_opt_perm(
  [perm_id] [smallint] NOT NULL,
  [permutation] [nvarchar](4) NOT NULL,
  [level1] [nvarchar](6) NOT NULL,
  [level2] [nvarchar](6) NOT NULL,
  [level3] [nvarchar](6) NOT NULL,
  [level4] [nvarchar](6) NOT NULL
  INSERT INTO cell_opt_perm ([perm_id], [permutation], [level1], [level2], [level3], [level4])
  VALUES (1,'LLLL','LOW','LOW','LOW','LOW'),
  (2,'LLLM','LOW','LOW','LOW','MEDIUM'),
  (3,'LLLH','LOW','LOW','LOW','HIGH'),
  (4,'LLML','LOW','LOW','MEDIUM','LOW'),
  (5,'LLMM','LOW','LOW','MEDIUM','MEDIUM'),
  (6,'LLMH','LOW','LOW','MEDIUM','HIGH'),
  (7,'LLHL','LOW','LOW','HIGH','LOW'),
  (8,'LLHM','LOW','LOW','HIGH','MEDIUM'),
  (9,'LLHH','LOW','LOW','HIGH','HIGH'),
  (10,'LMLL','LOW','MEDIUM','LOW','LOW'),
  (11,'LMLM','LOW','MEDIUM','LOW','MEDIUM'),
  (12,'LMLH','LOW','MEDIUM','LOW','HIGH'),
  (13,'LMML','LOW','MEDIUM','MEDIUM','LOW'),
  (14,'LMMM','LOW','MEDIUM','MEDIUM','MEDIUM'),
  (15,'LMMH','LOW','MEDIUM','MEDIUM','HIGH'),
  (16,'LMHL','LOW','MEDIUM','HIGH','LOW'),
  (17,'LMHM','LOW','MEDIUM','HIGH','MEDIUM'),
  (18,'LMHH','LOW','MEDIUM','HIGH','HIGH'),
  (19,'LHLL','LOW','HIGH','LOW','LOW'),
  (20,'LHLM','LOW','HIGH','LOW','MEDIUM'),
  (21,'LHLH','LOW','HIGH','LOW','HIGH'),
  (22,'LHML','LOW','HIGH','MEDIUM','LOW'),
  (23,'LHMM','LOW','HIGH','MEDIUM','MEDIUM'),
  (24,'LHMH','LOW','HIGH','MEDIUM','HIGH'),
  (25,'LHHL','LOW','HIGH','HIGH','LOW'),
  (26,'LHHM','LOW','HIGH','HIGH','MEDIUM'),
  (27,'LHHH','LOW','HIGH','HIGH','HIGH'),
  (28,'MLLL','MEDIUM','LOW','LOW','LOW'),
  (29,'MLLM','MEDIUM','LOW','LOW','MEDIUM'),
  (30,'MLLH','MEDIUM','LOW','LOW','HIGH'),
  (31,'MLML','MEDIUM','LOW','MEDIUM','LOW'),
  (32,'MLMM','MEDIUM','LOW','MEDIUM','MEDIUM'),
  (33,'MLMH','MEDIUM','LOW','MEDIUM','HIGH'),
  (34,'MLHL','MEDIUM','LOW','HIGH','LOW'),
  (35,'MLHM','MEDIUM','LOW','HIGH','MEDIUM'),
  (36,'MLHH','MEDIUM','LOW','HIGH','HIGH'),
  (37,'MMLL','MEDIUM','MEDIUM','LOW','LOW'),
  (38,'MMLM','MEDIUM','MEDIUM','LOW','MEDIUM'),
  (39,'MMLH','MEDIUM','MEDIUM','LOW','HIGH'),
  (40,'MMML','MEDIUM','MEDIUM','MEDIUM','LOW'),
  (41,'MMMM','MEDIUM','MEDIUM','MEDIUM','MEDIUM'),
  (42,'MMMH','MEDIUM','MEDIUM','MEDIUM','HIGH'),
  (43,'MMHL','MEDIUM','MEDIUM','HIGH','LOW'),
  (44,'MMHM','MEDIUM','MEDIUM','HIGH','MEDIUM'),
  (45,'MMHH','MEDIUM','MEDIUM','HIGH','HIGH'),
  (46,'MHLL','MEDIUM','HIGH','LOW','LOW'),
  (47,'MHLM','MEDIUM','HIGH','LOW','MEDIUM'),
  (48,'MHLH','MEDIUM','HIGH','LOW','HIGH'),
  (49,'MHML','MEDIUM','HIGH','MEDIUM','LOW'),
  (50,'MHMM','MEDIUM','HIGH','MEDIUM','MEDIUM'),
  (51,'MHMH','MEDIUM','HIGH','MEDIUM','HIGH'),
  (52,'MHHL','MEDIUM','HIGH','HIGH','LOW'),
  (53,'MHHM','MEDIUM','HIGH','HIGH','MEDIUM'),
  (54,'MHHH','MEDIUM','HIGH','HIGH','HIGH'),
  (55,'HLLL','HIGH','LOW','LOW','LOW'),
  (56,'HLLM','HIGH','LOW','LOW','MEDIUM'),
  (57,'HLLH','HIGH','LOW','LOW','HIGH'),
  (58,'HLML','HIGH','LOW','MEDIUM','LOW'),
  (59,'HLMM','HIGH','LOW','MEDIUM','MEDIUM'),
  (60,'HLMH','HIGH','LOW','MEDIUM','HIGH'),
  (61,'HLHL','HIGH','LOW','HIGH','LOW'),
  (62,'HLHM','HIGH','LOW','HIGH','MEDIUM'),
  (63,'HLHH','HIGH','LOW','HIGH','HIGH'),
  (64,'HMLL','HIGH','MEDIUM','LOW','LOW'),
  (65,'HMLM','HIGH','MEDIUM','LOW','MEDIUM'),
  (66,'HMLH','HIGH','MEDIUM','LOW','HIGH'),
  (67,'HMML','HIGH','MEDIUM','MEDIUM','LOW'),
  (68,'HMMM','HIGH','MEDIUM','MEDIUM','MEDIUM'),
  (69,'HMMH','HIGH','MEDIUM','MEDIUM','HIGH'),
  (70,'HMHL','HIGH','MEDIUM','HIGH','LOW'),
  (71,'HMHM','HIGH','MEDIUM','HIGH','MEDIUM'),
  (72,'HMHH','HIGH','MEDIUM','HIGH','HIGH'),
  (73,'HHLL','HIGH','HIGH','LOW','LOW'),
  (74,'HHLM','HIGH','HIGH','LOW','MEDIUM'),
  (75,'HHLH','HIGH','HIGH','LOW','HIGH'),
  (76,'HHML','HIGH','HIGH','MEDIUM','LOW'),
  (77,'HHMM','HIGH','HIGH','MEDIUM','MEDIUM'),
  (78,'HHMH','HIGH','HIGH','MEDIUM','HIGH'),
  (79,'HHHL','HIGH','HIGH','HIGH','LOW'),
  (80,'HHHM','HIGH','HIGH','HIGH','MEDIUM'),
  (81,'HHHH','HIGH','HIGH','HIGH','HIGH')
  CREATE TABLE spat_idx_test_result(
  [perm_id] [int] NOT NULL,
  [num_cells] [int] NOT NULL,
  [permut] [nvarchar](4) NOT NULL,
  [g1t1] [bigint] NULL,
  [g1t2] [bigint] NULL,
  [g1t3] [bigint] NULL,
  [g1t4] [bigint] NULL,
  [g2t1] [bigint] NULL,
  [g2t2] [bigint] NULL,
  [g2t3] [bigint] NULL,
  [g2t4] [bigint] NULL,
  [PF_EFF][float] NULL,
  [IF_EFF][float] NULL,
  [GRIDL1] [int] NULL,
  [GRIDL2] [int] NULL,
  [GRIDL3] [int] NULL,
  [GRIDL4] [int] NULL,
  [TPIR] [bigint] NULL,
  [TPIP] [bigint] NULL,
  [ANOIRPBR] [bigint] NULL,
  [TNOOCILFQ] [bigint] NULL,
  [TNOOCIL3FQ] [bigint] NULL,
  [TNOOCIL4FQ] [bigint] NULL,
  [TNOOCIL0II] [bigint] NULL,
  [TNOOCIL4II] [bigint] NULL,
  [TNOIOIL3FQ] [bigint] NULL,
  [TNOIOIL4FQ] [bigint] NULL,
  [ITTCNTLGP] [float] NULL,
  [INTTTCNTLGP] [float] NULL,
  [BTTCNTLGP] [float] NULL,
  [ACPONTLGP] [float] NULL,
  [AOPG] [float] NULL,
  [NORSBPF] [bigint] NULL,
  [NORSBIF] [bigint] NULL,
  [NOTSFIC] [bigint] NULL,
  [NORO] [bigint] NULL,
  [PORNBPF] [float] NULL,
  [POPFRSBIF] [float] NULL
  INSERT INTO dbo.spat_idx_test_result
  VALUES (0,16,0,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL)
END
/* delete all rows from "spat_idx_test_result" table. This makes it ready to stuff in new results.
  !!!WARNING!!! if your test was interupted, the table will be cleared out and the test will
  begin from the beginning. You could try to modify this to start where you left off but
  I didn't have time and this worked well enough for me. */
DELETE FROM spat_idx_test_result
  WHERE perm_id != 0
/* set up counters */
DECLARE @a1 INT
DECLARE @a2 INT
DECLARE @a3 INT
DECLARE @a4 INT
/* set up variables to hold high/medium/low values and permutation to use in rebuilding
   the spatial index and recording stats */
DECLARE @lev1 VARCHAR(6)
DECLARE @lev2 VARCHAR(6)
DECLARE @lev3 VARCHAR(6)
DECLARE @lev4 VARCHAR(6)
DECLARE @permut VARCHAR(6)
DECLARE @num_cell VARCHAR(4)
DECLARE @time_str VARCHAR(20)
DECLARE @perm_id VARCHAR(20)
DECLARE @x xml
DECLARE @pf_eff FLOAT
/* create variables to hold timestamps for beginning and ending of test queries */
DECLARE @start_t DATETIME
DECLARE @end_t DATETIME
DECLARE @elapse_t INT
/* begin looping through cell option permutations */
SET @a1 = @min_cells_per_obj
WHILE @a1 <= @max_cells_per_obj
  BEGIN
  SET @a2 = 1
  PRINT 'Started Testing for ' +CAST(@a1 AS VARCHAR(10)) +' cells per object'
  WHILE @a2 < 82
  BEGIN
  SELECT @lev1 = level1, @lev2 = level2, @lev3 = level3, @lev4 = level4 FROM cell_opt_perm WHERE perm_id = @a2
  SET @permut = '''' +(SELECT permutation FROM cell_opt_perm WHERE perm_id = @a2) +''''
  EXEC
  CREATE SPATIAL INDEX ' +@idxnm +' ON ' +@tabnm +'
  [SHAPE]
  USING  GEOGRAPHY_GRID
  WITH
  --MAKE SURE YOU EDIT THE BOUNDING BOX TO BE EXACTLY EQUAL TO THE BOUNDING
  --BOX OF YOUR SPATIAL TABLE
  GRIDS =(LEVEL_1 = ' +@lev1 +' ,LEVEL_2 = ' +@lev2 +' ,LEVEL_3 = ' +@lev3 +' ,LEVEL_4 = ' +@lev4 +' ),
  CELLS_PER_OBJECT = ' +@a1 +' ,
  PAD_INDEX  = OFF,
  SORT_IN_TEMPDB = OFF,
  DROP_EXISTING = ON,
  ALLOW_ROW_LOCKS  = ON,
  ALLOW_PAGE_LOCKS  = ON,
  FILLFACTOR = 100
  ON [PRIMARY]
  PRINT 'Re-built index to ' +@permut
  SET @a3 = 1
  SET @a4 = 1
  WHILE @a3 < 5
  BEGIN
  SET @start_t = GETDATE()
  EXEC
  'CREATE TABLE #tmp_tab (shp GEOGRAPHY)
  DECLARE @g1 GEOGRAPHY
  SET @g1 = ' +@testgeom1 +'
  INSERT #tmp_tab (shp)
  SELECT
  r.Shape AS shp
  FROM
  ' +@tabnm +' r
  WHERE
  r.SHAPE.STIntersects(@g1) = 1
  DROP TABLE #tmp_tab'
  SET @end_t = GETDATE()
  SET @elapse_t = (SELECT DATEDIFF(MS, @start_t, @end_t))
  SET @num_cell = CAST(@a1 AS VARCHAR(6))
  SET @time_str = CAST(@elapse_t AS VARCHAR(20))
  IF @a3 = 1
  BEGIN
  IF (SELECT TOP 1 perm_id FROM spat_idx_test_result) IS NULL
  BEGIN
  SET @perm_id = 1
  END
  ELSE
  BEGIN
  SET @perm_id = CAST((SELECT MAX(perm_id+1) FROM spat_idx_test_result) AS VARCHAR(20))
  END
  EXEC
  INSERT INTO spat_idx_test_result (perm_id, num_cells, permut, g1t' +@a3 +')
  VALUES (' +@perm_id +', ' +@num_cell +', ' +@permut +', ' +@time_str +')'
  END
  ELSE
  EXEC
  UPDATE spat_idx_test_result
  SET
  num_cells = ' +@num_cell +',
  permut = ' +@permut +',
  g1t' +@a3 +' = ' +@time_str +'
  WHERE perm_id = ' +@perm_id
  SET @a3 = @a3 + 1
  END
  WHILE @a4 < 5
  BEGIN
  EXEC
  DECLARE @g2 GEOGRAPHY
  SET @g2 = ' +@testgeom2 +'
  SELECT
  r.Shape AS shp
  FROM
  ' +@tabnm +' r
  WHERE
  r.SHAPE.STIntersects(@g2) = 1
  EXEC
  DECLARE @geom geography
  DECLARE @x xml
  DECLARE @PFVALUE float
  DECLARE @IFVALUE float
  DECLARE @GRIDL1VALUE int
  DECLARE @GRIDL2VALUE int
  DECLARE @GRIDL3VALUE int
  DECLARE @GRIDL4VALUE int
  DECLARE @TPIRVALUE bigint
  DECLARE @TPIPVALUE bigint
  DECLARE @ANOIRPBRVALUE bigint
  DECLARE @TNOOCILFQVALUE bigint
  DECLARE @TNOOCIL0IIVALUE bigint
  DECLARE @TNOOCIL4IIVALUE bigint
  DECLARE @TNOOCIL3FQVALUE bigint
  DECLARE @TNOOCIL4FQVALUE bigint
  DECLARE @TNOIOIL3FQVALUE bigint
  DECLARE @TNOIOIL4FQVALUE bigint
  DECLARE @ITTCNTLGPVALUE float
  DECLARE @INTTTCNTLGPVALUE float
  DECLARE @BTTCNTLGPVALUE float
  DECLARE @ACPONTLGPVALUE float
  DECLARE @AOPGVALUE float
  DECLARE @NORSBPFVALUE bigint
  DECLARE @NORSBIFVALUE bigint
  DECLARE @NOTSFICVALUE bigint
  DECLARE @NOROVALUE bigint
  DECLARE @PORNBPFVALUE float
  DECLARE @POPFRSBIFVALUE float
  --MAKE SURE YOU EDIT GEOGRAPHY VARIABLE BELOW TO REPRESENT A POLYGON
  --THAT IS WITHIN YOUR BOUNDING BOX
  SET @geom = geography::STPolyFromText(''POLYGON ((-83.883490 35.440092, -83.896426 35.715280, -83.121432 35.787017, -83.124960 35.510653, -83.883490 35.440092))'', 4269)
  --MAKE SURE YOU SPECIFY THE NAME OF YOUR SPATIAL TABLE
  --AND THE NAME OF THE SPATIAL INDEX
  -- IN THE sp_help_spatial_geography_index_xml VARIABLES
  exec sp_help_spatial_geography_index_xml GRSM_TRAILS , GRSM_TRAILS_IDX , 1, @geom, @x output
  SET @PFVALUE =  @x.value(''(/Primary_Filter_Efficiency/text())[1]'', ''float'')
  SET @IFVALUE =  @x.value(''(/Internal_Filter_Efficiency/text())[1]'', ''float'')
  SET @GRIDL1VALUE =  @x.value(''(/Grid_Size_Level_1/text())[1]'', ''int'')
  SET @GRIDL2VALUE =  @x.value(''(/Grid_Size_Level_2/text())[1]'', ''int'')
  SET @GRIDL3VALUE =  @x.value(''(/Grid_Size_Level_3/text())[1]'', ''int'')
  SET @GRIDL4VALUE =  @x.value(''(/Grid_Size_Level_4/text())[1]'', ''int'')
  SET @TPIRVALUE =  @x.value(''(/Total_Primary_Index_Rows/text())[1]'', ''bigint'')
  SET @TPIPVALUE =  @x.value(''(/Total_Primary_Index_Pages/text())[1]'', ''bigint'')
  SET @ANOIRPBRVALUE =  @x.value(''(/Average_Number_Of_Index_Rows_Per_Base_Row/text())[1]'', ''bigint'')
  SET @TNOOCILFQVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level0_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOOCIL0IIVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level0_In_Index/text())[1]'', ''bigint'')
  SET @TNOOCIL4IIVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level4_In_Index/text())[1]'', ''bigint'')
  SET @TNOOCIL3FQVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level3_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOOCIL4FQVALUE =  @x.value(''(/Total_Number_Of_ObjectCells_In_Level4_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOIOIL3FQVALUE =  @x.value(''(/Total_Number_Of_Interior_ObjectCells_In_Level3_For_QuerySample/text())[1]'', ''bigint'')
  SET @TNOIOIL4FQVALUE =  @x.value(''(/Total_Number_Of_Interior_ObjectCells_In_Level4_For_QuerySample/text())[1]'', ''bigint'')
  SET @ITTCNTLGPVALUE =  @x.value(''(/Interior_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'')
  SET @INTTTCNTLGPVALUE =  @x.value(''(/Intersecting_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'')
  SET @BTTCNTLGPVALUE =  @x.value(''(/Border_To_Total_Cells_Normalized_To_Leaf_Grid_Percentage/text())[1]'', ''float'')
  SET @ACPONTLGPVALUE =  @x.value(''(/Average_Cells_Per_Object_Normalized_To_Leaf_Grid/text())[1]'', ''float'')
  SET @AOPGVALUE =  @x.value(''(/Average_Objects_PerLeaf_GridCell/text())[1]'', ''float'')
  SET @NORSBPFVALUE =  @x.value(''(/Number_Of_Rows_Selected_By_Primary_Filter/text())[1]'', ''bigint'')
  SET @NORSBIFVALUE =  @x.value(''(/Number_Of_Rows_Selected_By_Internal_Filter/text())[1]'', ''bigint'')
  SET @NOTSFICVALUE =  @x.value(''(/Number_Of_Times_Secondary_Filter_Is_Called/text())[1]'', ''bigint'')
  SET @NOROVALUE =  @x.value(''(/Number_Of_Rows_Output/text())[1]'', ''bigint'')
  SET @PORNBPFVALUE =  @x.value(''(/Percentage_Of_Rows_NotSelected_By_Primary_Filter/text())[1]'', ''float'')
  SET @POPFRSBIFVALUE =  @x.value(''(/Percentage_Of_Primary_Filter_Rows_Selected_By_Internal_Filter/text())[1]'', ''float'')
  SET
  g2t' +@a4 +' = ' +@time_str +',
  PF_EFF = @PFVALUE,
  IF_EFF = @IFVALUE,
  GRIDL1 = @GRIDL1VALUE,
  GRIDL2 = @GRIDL2VALUE,
  GRIDL3 = @GRIDL3VALUE,
  GRIDL4 = @GRIDL4VALUE,
  TPIR = @TPIRVALUE,
  TPIP = @TPIPVALUE,
  ANOIRPBR = @ANOIRPBRVALUE,
  TNOOCILFQ = @TNOOCILFQVALUE,
  TNOOCIL0II = @TNOOCIL0IIVALUE,
  TNOOCIL4II = @TNOOCIL4IIVALUE,
  TNOOCIL3FQ =  @TNOOCIL3FQVALUE,
  TNOOCIL4FQ =  @TNOOCIL4FQVALUE,
  TNOIOIL3FQ = @TNOIOIL3FQVALUE,
  TNOIOIL4FQ = @TNOIOIL4FQVALUE,
  ITTCNTLGP = @ITTCNTLGPVALUE,
  INTTTCNTLGP = @INTTTCNTLGPVALUE,
  BTTCNTLGP = @BTTCNTLGPVALUE,
  ACPONTLGP = @ACPONTLGPVALUE,
  AOPG = @AOPGVALUE,
  NORSBPF = @NORSBPFVALUE,
  NORSBIF = @NORSBIFVALUE,
  NOTSFIC = @NOTSFICVALUE,
  NORO = @NOROVALUE,
  PORNBPF = @PORNBPFVALUE,
  POPFRSBIF = @POPFRSBIFVALUE
  SET @a4 = @a4 + 1
  END
  SET @a2 = @a2 + 1
  END
  SET @a1 = @a1 + 1
  END
PRINT 'Testing of ' +@tabnm +' spatial index: ' +@idxnm +' is complete!'
GO
And execute like so:
DECLARE @BOUNDING VARCHAR(MAX)
SET @BOUNDING = 'geography::STPolyFromText(''POLYGON ((-83.883490 35.440092, -83.896426 35.715280, -83.121432 35.787017, -83.124960 35.510653, -83.883490 35.440092))'', 4269)'
DECLARE @QUERY VARCHAR(MAX)
SET @QUERY = 'geography::STPolyFromText(''POLYGON ((-83.883490 35.440092, -83.896426 35.715280, -83.121432 35.787017, -83.124960 35.510653, -83.883490 35.440092))'', 4269)'
EXEC sp_tune_spatial_index 'GRSM_TRAILS', 'GRSM_TRAILS_IDX', 4096, 4096, @BOUNDING, @QUERY
GO
About the Author
This is a personal account and does not reflect the view or policies of my org.
