arcpy.MakeFeatureLayer_management how to work with versioned layers
4173
12-18-2015 05:18 AM
JoseSanchez
Hello everyone,
The following source code shows how to copy features from one feature class (Source) to another feature class (Destination) when both features are versioned.And then remove features copied from the Source
The steps:
  • create a new SDE version a  WorkingVersion
  • select Source Feature Class with features to be copied and make a Feature Layer
  • select Destination Feature Class make a Feature layer
  • ChangeVersion of both feature layers to the  WorkingVersion
  • append features to destination Feature Class
  • delete features from Source Feature Class that were appended
 versions = arcpy.ListVersions(database)
     # Print the versions available to the user
     for version in versions:
        print(version)
        if version == WorkingVersion:
            # Execute DeleteVersion
            arcpy.DeleteVersion_management(database, WorkingVersion)
     # Execute CreateVersion
     arcpy.CreateVersion_management(database, ParentVersion, WorkingVersion, "PUBLIC")
     # Select records with STATUS = 'Completed'  and Historical  records
     arcpy.MakeFeatureLayer_management(SourceFeatureCalss, SourceLayer, "STATUS = 'Completed'", "", " .....")
    # Process: Make Feature Layer (2)
     arcpy.MakeFeatureLayer_management(EditableFeatureClass, AppendedLayer, "", "", "......")
    #  Change Both layers SourceLayer and AppendedLayer To OWNER.WORKINGVERSION version
     arcpy.ChangeVersion_management('SourceLayer','TRANSACTIONAL', WorkingVersion,'')
     # Change to HISTORICALAASIS version
     arcpy.ChangeVersion_management('AppendedLayer','TRANSACTIONAL', WorkingVersion,'')
     # Process: Append...
     arcpy.Append_management("SourceLayer", AppendedLayer, "TEST", "", "")
     # Process: Delete Features...
     arcpy.DeleteFeatures_management(SourceLayer)
     arcpy.ReconcileVersions_management(database,
                                   "ALL_VERSIONS",
                                   "OWNER.ParentVersion",
                                   "OWNER.WORKINGVERSION",
                                   "LOCK_ACQUIRED",
                                   "NO_ABORT",
                                   "BY_OBJECT",
                                   "FAVOR_TARGET_VERSION",
                                   "POST",
                                   "KEEP_VERSION",
                                   scratchFolder + "RecLog.txt")
