Will custom functions in user.py be listed in the Expression column in Data Loading Worksheets?
766
09-21-2025 06:34 AM
GISP00
When adding new functions to the user.py file, should the functions appear as a list in the Expression column, similar to how the base.py functions appear?
Opinions and advice are my own and not the views of my employer.
This is my personal account. I am not acting as an agent for my employer.
MikeMillerGIS
Esri Frequent Contributor
You will need to run Update Data Loading Workspace.  This will create a new workspace and add any user functions to the dropdown.
MikeMillerGIS
MikeMillerGIS
You can also manually add the function name to the hidden lookup sheet.
Right click the tabs and select unhide
select -Lookup-
scroll to the bottom and add your function, in my example, I added create_foo()
