Setting raster image coordinate system with known lat/long range
3432
08-28-2016 11:51 AM
LamaZip
I have downloaded a SST image of the United Kingdom. It is in PNG format with no coordinate system.
I know the dimensions of my image and its lat/long range. However, i'm not sure what approach to take in Arcmap to set the co-ordinate system.
There is a web-page describing how to convert image co-ordinates to latitude/longitude but it is beyond my scope link
The image is apparently produced in Mercator projection
Note, this will need to be carried out on multiple rasters, so a automated/batch approach, which isn't interactive or manual, is required
Details of Image
Dimension   1596 x 1617
BPP 8
Latitude range  47 — 62.999108
Longditude range    -15 — 13
Pixel dimensions    1.100149 x 1.100149
AbdullahAnter
Honored Contributor
LamaZip
Could you give an example of how this would be achieved?
AbdullahAnter
Honored Contributor
  • Display georeference toolbar in arc map.
  • Add your image (Add Data).
  • Click the Add Control Points tool Add Control Points.
  • Click a known location in the unreferenced image to add the first coordinate in the link. (the corner of image)
  • Right-click the image and click Input Lat and Long.
  • Type the reference coordinates on the Enter Coordinates dialog box
  • Click Ok.
  • Do this for two corners of image.
