Offset Coordinates
9421
11
07-11-2016 01:45 PM
DavidCobb1
I have an excel file that has XY data in state plane format.  The coordinates were taken from a survey plat and each coordinate has its own offset value.  Is there an easy way or a tool that I can use that will shift the coordinates to their actual location after the offset is applied?
Thank you!
Esri Community
Esri Surveying
Tags (1)
MelitaKennedy
Esri Notable Contributor
If the table lists easting/northing values, that should be fine unless they're ground coordinates rather than grid (projected) coordinates. I have a feeling that the plat has more information like the direction of the lines that these station coordinates plus offsets refer to.
Melita
DavidCobb1
I do not see any other information on the Plat that would be able to help me identify how I can account for the offset distances when plotting the northing/easting values.
