Calculating a centroid in GCS vs PCS
914
05-09-2025 07:26 AM
StephenKing3
I'm using ArcGIS Pro to calculate the centroid of a polygon in both geographic (WGS 1984) and projected (WGS 1984 UTM Zone 30 North) coordinate systems. I understand that the actual location of the centroid will be slightly different between the two, even though the lat and long are almost identical. However, when comparing the output for two different polygons (one located further south than the other), the distance between the point locations for the more southerly polygon is greater than for the more northerly one. Can someone explain why that is?
Thanks.
DavidPike
MVP Notable Contributor
I'd avoid any centroid calculations of GCS features as it seems to calculate the centroid as if the lat/lon coords were transcribed onto a cartesian plane i.e. Plate Carree.
https://community.esri.com/t5/arcgis-pro-questions/centroid-of-polygon-stored-in-a-geographic/m-p/16...
