How to manage your tags
1862
08-30-2020 09:24 AM
Starting May 8, 2026, the tag feature will no longer be available for most members. Following a phased approach, this feature will be turned off for all members and historic tags will eventually be removed from posts. Learn more: Upcoming Change to Post Tags
What are tags?
tag is a single keyword or phrase that describes the topic, theme, or subject of a post. You can add as many tags as you want, and so can other community members. For example, in a post about a mouse, you might add these tags: mouse, USB mouse, optical mouse, wireless, DPI.
How do I add a tag?
You can tag your content in two ways:
  • When you Create A Post, enter your tags in the field for Tags.
  • You can also add tags after you publish your post by selecting Add tag at the bottom of your content.
To add a tag to other member’s posts:
  1. Navigate to an interesting post or comment.
  2. Click Add tags and type your tags (separated by commas).
  3. Click Add.
If you do not see the option to add tags to a post, the feature may have been disabled for the post. You have the option to select whether you want community members to be able to add tags to a post.
Be sure to use commas between tags.
To find your tags
You can find posts that you’ve tagged by going to My Profile and clicking the tags under Latest Tags.
Comments
MarioSapp
Observer
Thanks for welcoming me in
#ynic
Version history
Last update:
‎05-07-2026 10:42 AM
Updated by:
Contributors
