Some user avatars showing as broken link
6398
19
10-23-2024 06:55 AM
PeterKnoop
MVP Regular Contributor
Whether I'm logged in or not, some user's avatars are showing as broken links.
When I am logged in, my own avatar in the top-right corner is showing as a broken link. It also shows a broken link on the Avatars tab when I go to my settings.
I have not changed my avatar in long time.
KenBuja
MVP Esteemed Contributor
Are you seeing them like the one for RobertoRossi?
I'm noticing others like this too
PeterKnoop
Yep. Not all, but many.
jcarlson
The broken ones show up with paths like this:
https://community.esri.com/legacyfs/online/esri/avatars/some_filename.png
Working avatars come from paths like this:
/t5/image/serverpage/image-id/55220i5E1AF41F327EBFC0/image-dimensions/50x50/image-coordinates/0%2C1%2C2970%2C2971/constrain-image/false?v=v2
I'm guessing that "legacyfs" was stuff ported over from GeoNet, and is currently unavailable.
- Josh Carlson
Kendall County GIS
JesseCloutier
Esri Community Manager
Hi @KenBuja, @PeterKnoop, and @jcarlson, we became aware of the issue this morning and are looking into it. Some of our team is currently traveling back from a conference so that progress is staggered, but it is in process. Josh, I've shared your observation with our team member leading that investigation—thanks for speaking up about that detail.
Jesse Cloutier
Community Manager, Engagement & Content
TimMinter
Looks like the CMS configuration got jiggled so there's no way to select an off-menu avatar.  That's my UX, anyway.
SimiBasu
Hi @TimMinter can you please try now and see if you can select an off-menu avatar. @JesseCloutier  FYI this should be fixed.
TimMinter
Yep, fixed!  Thanks @SimiBasu
AZendel
It looks like ESRI has revoked the ability for us to use an avatar of our choosing since we can't upload an image any longer (unless  I missed something).
SimiBasu
Hi @AZendel can you please try now and see if you can select an off-menu avatar. @JesseCloutier  FYI this should be fixed.
