If Questions are actually Topics, then where are true Questions on Esri Community?
2363
01-29-2024 10:02 AM
AllenDailey1
I have a question about Esri Community; the question was sparked when I was looking at my badges.  I thought I should have another badge for posting questions.  So I found my "private stats," (see below) and it says I have posted zero questions.  I guess when I post questions in communities like ArcGIS Pro Questions, it actually counts as starting a topic (?).  This feels confusing because the discussion board is called "Questions."  Yet in stats, it is "topics."
That leads me to the question, if that doesn't count as questions, then what does?  In what part of Esri Community are true "questions" posted?
JesseCloutier
Esri Community Manager
@AllenDailey1, the Private Stats widget comes with some 'out-of-the-box' language from our platform vendor, which is  why you're seeing an (understandably) confusing difference between what it lists as Topics and what it lists as Questions. The original Q&A type post that the platform came with isn't something we use—if we did and you were publishing posts in it, those would be tracked in the Questions Posted row you've highlighted. Instead, we use the Topics type post for what we have renamed as Questions throughout Esri Community. That's why you're seeing 30 there (the number of original Questions posts you've published) and the Replies row underneath it references how many responses on Topics (Questions) you've published. I hope I didn't make that more confusing—do let me know if it wasn't clear!
Jesse Cloutier
Community Manager, Engagement & Content
Bud
Legendary Contributor
How can I see my stats? Can you post the link?
KenBuja
It's at the bottom of your profile page
JesseCloutier
Jesse Cloutier
AllenDailey1
Thank you very much, @JesseCloutier !  That definitely makes sense.  😊
