Code Sample containing "@id" is being reformatted upon saving
1455
01-17-2022 09:22 AM
jcarlson
Hello! Came across what I believe to be a minor bug in the code blocks on Community posts.
var id = "@id"
In composing this post, here's what I see:
I'm going to save this post, and if it behaves like I saw in another post recently, it's going to be different. Will edit this post shortly with the results.
- Josh Carlson
Kendall County GIS
jcarlson
Well, it didn't do it. I'll post the full code from the related post:
var fs = FeatureSetByName($datastore, "Hydrant Inspections")
var id = $feature.hydrantID // just replace with your own field name as needed
// Get inspections for clicked hydrant
var filt_fs = Filter(fs, "hydrantID = @ID")
// Order inspections with most recent first
var ordered_fs = OrderBy(filt_fs, "InspectionDate DESC")
// Return most recent inspection specific to hydrant
var inspection = First(fs)
return inspection.InspectionDate
Perhaps it behaves differently in a reply than the main post, or perhaps that other post was just a fluke. Again, what I'm seeing while composing:
- Josh Carlson
Kendall County GIS
jcarlson
There it goes!
Stranger still, if I go to edit that post and change the expression the '@ID' portion of the code block is dropped entirely.
- Josh Carlson
Kendall County GIS
