Basemap service
2749
07-19-2022 02:07 PM
kurdishbrwar
Greetings to all, praise be to God, I have finished drawing the map of Dohuk Governorate in northern Iraq - the Kurdistan Region of Iraq - with high accuracy (the map drawing scale is 1/15,000) based on the mapping services provided by ESRI company, which helps in the drawing process with great accuracy. They have many thanks, and good luck To all, your colleague from Iraq Sabah - Duhok city.
JesseCloutier
Esri Community Manager
Congratulations on your accomplishment, @kurdishbrwar! That sounds like no small feat and we appreciate hearing how Esri products made completing your map possible. All the best as you continue your mapping journey!
Jesse Cloutier
Community Manager, Engagement & Content
kurdishbrwar
Greetings, Mr. Jesse, thank you for your nice comment. This is a map that I worked on and it will be a gateway to a lot of work in the near future. Greetings to your honorable side.
JesseCloutier
Thanks for following up to share your map, @kurdishbrwar! I'm glad to hear that it's an important starting point for other work you'll be doing.
Jesse Cloutier
