I would like to use the Business Analyst Online mapping feature to identify underlying zoning for properties. Is this a possibility with a level I subscription?
There is no zoning data in that is provided with Business Analyst. You may want ot see if there is zoning data available as a feature layer or web map in your area of interest. You can add web map data under the "Add data" menu item described here:
Thank you, Garry. Your prompt response is greatly appreciated.
Sent via the Samsung Galaxy S® 6, an AT&T 4G LTE smartphone
