For example I have a POI and a BANK Table.
I want when I create a feature on the POI Table I want to have also the fields from Bank.
I can do linked fields. For example in the POI table the POI_TYPE is linked to a POI_TYPE table and display a dropdown combo.
But in the case I select POI_TYPE = Bank I want multiple fields like how many ATM has, do have auto service, etc.
Are you looking at desktop (ArcMap) level ? or looking for Arcobjects programming code ?
Venkat
Yes, I want add new POI in ArcMap
Hi!
First, You could do a domain with the ID's that you need,
Creating a new coded value domain—ArcGIS Help | ArcGIS Desktop
next, you should to do a relate table between POI_TYPE of the POI table and POI_TYPE of the BANK table, You could do this, right clic on the POI Table/Joins and Relates/Relate
About joining and relating tables—Help | ArcGIS for Desktop
I hope this help you
Regards
