Swipe app: series button in user version vs. developer version
1950
6
06-03-2014 01:20 PM
CONABIONC_for_Knowledge_and_Us
Dear all:
After my previous post (http://forums.arcgis.com/threads/111167-Swipe-app-limit-zoom-levels) I started working with the devolper-files of the swipe app. However, the series buttons look different in the developer version (DV) than in the user version (UV).
Would it be difficult to add the series buttons´ layout of the UV to the DV? Or vice versa: add the zoom-limit I added to the DV also to the UV?
Thank you & best regards,
Flo
MarkCooney
Hi Flo,
It looks like a typo in the index.html.  The loading of the file is around line 183, and if you change:
    loadCSS("app/storymaps/swipe/ui/desktop/seriesPanel.css");
to:
    loadCSS("app/storymaps/swipe/ui/desktop/SeriesPanel.css");
That should do the trick.
-Mark
MarkCooney
Hello Flo,
What are the differences that you are seeing between the two versions?  If possible, could you provide some screen shots?
-Mark
Hi Mark,
with the UV I get this: http://speck.conabio.gob.mx/manglarfotos/MEX/modis/index.html (without zoom limit)
with the DV I get this: http://speck.conabio.gob.mx/manglarfotos/MEX/Swipe/src/ (with zoom limit)
The coordinates of the series buttons are not the same but that shouldn´t be the point.
thank you & best regards,
Flo
MarkCooney
Hi Flo,
It appears the file SeriesPanel.css is not loading.  Do you see that in the src\app\storymaps\swipe\ui\desktop folder?  I just downloaded the dev version from github and am seeing it there.  If you are missing the file, perhaps try downloading it again and add that file to your current version.
-Mark
Hi Mark,
I downloaded the dev-version once again and uploaded these original files, but the problem remains:
The SeriesPanel.css is where you said it should be.
More hints?
Flo
MarkCooney
Hi Flo,
to:
-Mark
Hi Mark,
yes - it was the typo in the index.html 🙂
muchas gracias & best regards,
Flo
