Shortlist Template Will Not Work
3435
06-16-2014 11:30 AM
MichaelD_Aprix
I've been looking on the forums and working on this issue for a couple of days now and cannot figure out what is wrong.  I have made a web map which fits the Storytelling Shortlist downloadable/configurable template, however it will not load.  I have tried uploading a .csv file, a shapefile and even though it is not supported, publishing a service from the desktop.  Nothing I made would work from my account.  The example templates, San Diego and Palm Springs work as well as one or two I have seen in threads.  I do not have any special characters in the attributes, I only have the designated attributes from the instructions, I have made bookmarks and at this point I have stripped everything from the map because I could not figure out which component was not working.
This is my web map:
http://hamilton1812.maps.arcgis.com/home/webmap/viewer.html?webmap=3949282b685d435587f5f18fce9406fc
And the shortlist
http://dora.hpc.hamilton.edu/sites/cwl.dhinitiative.org/shortlist/index.html?webmap=3949282b685d4355...
Again, there is no problem with the downloadable examples.  It's something I am missing in the map or the data.
RupertEssinger
Esri Alum
Your web map either doesn't exist or has not been shared publicly. That's why your Shortlist isn't working. If your web map was available publicly, it would work.
So this link has to work:
http://www.arcgis.com/home/item.html?id=3949282b685d435587f5f18fce9406fc
