Image 'float:right' in Map Journal
846
07-22-2020 07:24 AM
VarvaraTumasyeva1
Hi all,
I am working on a storymap with each section telling about one company. And I need to add a logo to it, floating in the upper right corner.
The result should be smth like this:
I tried both css and html, 'float:right' tag works everywhere except Esri Map Journal.
Has anyone run across this? Any workaround ideas?..
I would appreciate any help!
P.S. I use Map Journal, tested both in ArcGIS Online and Portal 10.6
