hyperlink in description field when using ArcGIS Server as source
2505
01-15-2014 04:09 AM
AdamOlson
I have noticed that some story maps have hyperlinks within the description field.
My story map uses a feature service from our ArcGIS server.  So how is it possible to create a hyperlink within a text field (the description field) in a feature class that is the service is using so that it shows up in the description for the story map?
GregoryL_Azou
Whatever the type of your data source, you can use HTML tags in all editable fields of a Map Tour.
So you have to know the basics of HTML to create a link.
The Help Tips guide you in creating a link, see attached image (we will include a friendly editor in the future).
[ATTACH=CONFIG]30670[/ATTACH]
Note that when you are using a Feature Service, depending on the server version and it's configuration, the supported HTML tags may be restricted to those listed here.
