How can I stop the Descriptions in a tabbed Story Map Series from covering the Legend and Zoom Slider in embedded Story Maps (Slider and Spyglass)?
802
01-28-2019 03:09 PM
JoshuaBailey1
OwenGeo
Esri Notable Contributor
Hi Joshua -- One option is to use the Side Accordion layout (in Settings > Layout), which is a different layout where the descriptions are located in a dedicated side panel that doesn't overlap the main stage content.
If you want to keep the Tabbed layout then in Settings > Layout options you can swap the description panel to the right side.
Owen Evans
