geotagging fails from flickr
3616
7
10-24-2014 05:27 AM
MatthewTucknott
This is driving me mad. I was hoping it would be a quick job to import my geo-tagged photos from flickr into a story map and they would be geo located in the right place.
I have set the appropriate flicker settings (when I upload the photos they have EXIF info and are correctly located on a map).
When I import them using the story map builder, the photos have no location. Is there some additional setting in Flickr that I am missing?
I have just enabled import for EXIF in flickr.
Any help would be appreciated. I wanted this to be a quick job...
Many thanks
Tuckers
MatthewTucknott
Justo to let anyone know.
I got this working. Not only do you have to set the global flags for location and sharing. I also found that I had to set the location and sharing oin the album I created. Once I did this it all worked.
Thansk for the various replies.
StephenSylvia
Flickr has two separate sharing options. One is to share the photo publicly, but there is also another options that you can set to share the location publicly. Can you verify that both of these are set correctly?
GregoryL_Azou
See the screenshot below
MatthewTucknott
GregoryL_Azou
weir that should be it.
And you confirm that your pictures appear geolocated when you view them on the Flickr Map?
I won't be able to dig more without your account and album info...
MatthewTucknott
Yep it appears on the map in flickr
deleted-user-eecV1RPyUfl1
I had a similar experience using Flickr.  If I recall, I went back and re-imported my photos a second time and the process worked.  No clue why that worked but it did.
MatthewTucknott
