Editing Tab name in shortlist story map
3650
13
12-04-2018 03:01 PM
ELIZABETHEBERLE
I am creating a story map and it's nearly complete. I am just trying to edit the name of one of my tabs. When I click on the edit tab button, it opens and I am able to change the color, but if I try to change the name of the tab, I get a red circle with a slash when I hover over the tab name, and I am unable to change the name. I also don't even see the other tabs for editing: 'add tab' and I forget what the other one is called.
Another issue I am having, which might be the root of this problem, is that my ap is always 'checking' up in the corner next to the 'save' box. And I mean it never stops.
Honestly, we would like to deploy this to the public, but I just need to change that tab name.
Thanks for any help you can provide.
Link to map:
https://wadnr.maps.arcgis.com/apps/Shortlist/index.html?appid=98a7fe4ea3764440ad59f0d9b0b280e3&edit=...
-Elizabeth
ELIZABETHEBERLE
Hi Rupert,
I wanted to let you know that our story map is now live. The web link is here:
https://www.dnr.wa.gov/go
And to get directly to the map is here:
Thanks again for all your support.
I tried emailing this, but it failed twice, so I'm trying this way.
We’ve already got a long list of updates, but wanted to get it live and into maintenance mode.
-Elizabeth
RupertEssinger
Esri Alum
Hi Elizabeth
Looks good. Sorry about that issue with the title. I'm not sure why it is doing that still for you. Perhaps you could spell out DNR in the subtitle instead? But up to you.
When you mentioned that you tried to email this, I'm not sure what email address you used.
Rupert
ELIZABETHEBERLE
I’ll definitely put that on my to-do list. Now that we are in maintenance mode, I can do small tweaks when I go in for updates.
Thanks again for all your support!
-Elizabeth
Elizabeth Eberle
Recreation GIS Cartographer/Analyst
360-902-1222
elizabeth.eberle@dnr.wa.gov<mailto:elizabeth.eberle@dnr.wa.gov>
www.dnr.wa.gov<http://www.dnr.wa.gov/>
RupertEssinger
Esri Alum
Sounds good.  A couple of other things I noticed:
- On this page Where to go, what to do | WA - DNR  , the embed code seems to be using a fixed width size frame, such that the Story Map doesn't resize in a responsive way if the page is displayed in a less wide window or mobile device. Using a relative width rather than fixed width works better. For example see: City of Scottsdale - City Construction Projects
- The Zoom menu in your Shortlist wraps onto a second line because the menu name is quite long. How about just making that name be 'Zoom' or similar to shortened it.
Rupert
