Change Map Journal Builder Theme??
3443
12-18-2015 07:32 AM
SSMGroup
I really enjoy the layout of the Map Journal Builder with the Floating Panel.  The only downside is that I want to change the color of the panel.  What part of the downloaded code can I edit to change the color?
RickeyFight
After you have downloaded and got it running on your server look here:
Esri/map-journal-storytelling-template-js · GitHub
It might take some css work but it is possible.
RickeyFight
