Export Map to PDF
5287
11-19-2015 09:33 AM
Randy_A_Stapleton
I am having an problem with map symbology when exporting a map to PDF. Some of the fill lines turn 'wavy'. I've tried a number of different setting from export options, but cannot get it to work. Any thoughts?
Tags (1)
ChrisDonohue__GISP
A variety of issues can occur when converting to PDF.  I'd start by checking your output settings.  It may be that your export quality is set very low.
Be sure that you can see all the export options.  If you have not already, click on the un-obvious triangle next to "Options" to open the additional tabs.
Then look at the various settings.  There are a wide variety of controls here, so let us know what settings you are using that caused the output issue.  This will provide more specifics to troubleshoot this, as there are a wide variety of settings with different effects.
Chris Donohue, GISP
Randy_A_Stapleton
Chris, Thanks for the reply. I have tried multiple settings & increased DPI up to 720. Still getting the same results.
ChrisDonohue__GISP
You may have already checked this particular setting, but if not.....
Here's another one that may be tripping things up:
Chris Donohue, GISP
DavidBarnes
Do you have anything that is causing rasterization (transparency, bitmap fills, etc.) of that layer or any above it? If so, you might try removing the things causing rasterization and see how it exports then to see if that makes any difference.
