Display Table XY Dayta
2395
9
03-03-2017 02:25 PM
DevinUnderwood2
I set everything correct but my points place me in the ocean, why ?
x,y in decimal degrees
DarrenWiens2
You're specifying a projection when your data are unprojected. Use a geographic coordinate reference system and then project.
DarrenWiens2
Probably because your data are in decimal degrees but you're specifying a projection in Display XY data...? Or, you've mixed up X and Y. Can you show the XY data dialog?
DevinUnderwood2
Example  -136.179137  25.945518 Decimal Degrees  is the location of data dialog when using identify tool
but the actual data coordinate is -117.10765, 33.121972
DanPatterson_Retired
did you calculate the coordinates in the featureclass or shapefile's table to ensure what the point object is supposed to be actually is?
DevinUnderwood2
No, since I did not export it as a feature class or shapefile, it is just an event.
DarrenWiens2
Please show the tool dialog where you've filled in the parameters for Display XY Data.
DevinUnderwood2
DarrenWiens2
DevinUnderwood2
That worked, I used WGS 1984. I was thinking I wanted it projected , but its decimal degrees so your saying I should use a GCS. Thank you.
JoshuaBixby
MVP Esteemed Contributor
If your question has been answered, please mark someone's response as the answer to close the question out.
