Why gives Export to CAD with Projection in environment different results to Project shape and the export to CAD?
733
06-29-2019 04:06 AM
TheDLH
I do have a *.shp in EPSG 25832. I ahve tried tow scenarios transform this to *.dwg in EPSG 31468:
1. Project shapefile and then export this to CAD
2. Export shapefile to CAD while setting 31468 as target CRS in the environment of the Export to CAD function.
1. Gives a correct *.dwg
2. Gives a *.dwg with a location shifted about 150 m to the soutwest.
Why is there a difference? It would be nice to have the second option as this is less work.
thanks,
TheDLH
MelitaKennedy
Esri Notable Contributor
When you project the shapefile, does the tool set a geographic/datum transformation? Export to CAD probably isn't and it doesn't look like it supports the geoprocessing environment for setting a default transformation. You could try that anyway--use the same transformation as the Project tool and see if it gives you the correct result.
Melita
