From DWG with extended data to Featureclass with attributes
9837
10
03-29-2017 08:27 AM
AlessandroValra
Hi. I saw many questions related to the same problem (e.g. "How to convert CAD file xdata into geodatabase?"), but could not really find a solution to this, so I am posting this as a new question.
I have a DWG created in AutoCAD. It has some "solid" entities. I am facing some problems integrating my CAD data with ArcGIS. Here they are:
  1. Although stated in the ESRI official documentation that solid entities should be read as multipatch natively, I fail to import them (the mutlipatch fc generated importing the dwg dataset from ArcCatalog is empty; also look at this thread on "gis.stackexchange"). Is it a recognised problem?
  2. Using the Quick Import tool of the Data Interoperability extension I was able to import the solid entities as multipatch geometries. However I cannot see the related extended data as attributes in the attribute table.
Before asking "How can I translate xdata into feature attributes?" I would like to know from ESRI or someone else facing such problem, "Which is the best procedure in AutoCAD to produce a DWG in order to import it into ArcGIS (ArcMap or Pro) preserving geometries AND attributes"?
I attached the DWG I am using. I am using ArcMap 10.4.1, and ArcGIS Pro 1.4. Many thanks in advance, I would highly appreciate any help!
AdrianWelsh
MVP Honored Contributor
Daniel,
This is an old blog but it might help:
Importing CAD data in ArcGIS Desktop 10 | ArcGIS Blog
You can use this tool: CAD to Geodatabase—Help | ArcGIS for Desktop
Also, here is a video Convert CAD To ArcGis - YouTube
