KML file layer not visible
3466
07-19-2016 02:32 PM
StanMance
I'm using a trial version of ArcGIS to evaluate for our needs. I created a basic map then imported a KML file to overlay and saved and all is good. However, when I try to view the map in the Explore App using an Iphone or Ipad, the Layer is not visible. Map message says, "Layer type not supported: KML".
I'm a novice with this program. Any Suggestions?
TanyaHaddad
In ArcMap you can right-click on your overlay in the layer listing, and do "Data Save As". Try saving as the Shapefile format, and then using that version instead of KML to see if that works for you.
