Create Street Name Validation
1540
14
05-07-2026 07:32 AM
SarahWright
I am trying to create an attribute rule that validates if a street name is in a master street table when being created. Here is the code I have so far, I am not sure where my syntax is wrong.
The expression needs to be case in-sensitive, the source data in the master table is mixed casing.
 Thanks in advance!
// 1. Access the reference table by name
// This must match the name of the layer in your database/service
var masterStreetName = Upper(FeatureSetByName($datastore, 'vwAddresserData_v2', ["FULLADDRESS"], false));
// 2. Get the address being entered/edited
var addresserStreetName = Upper($feature.FullStreetName);
// 3. Handle empty values (optional: allow or block nulls)
if (IsEmpty(addresserStreetName)) { return true; }
// 4. Filter the other table for matching addresses
// Use Upper() to ensure the comparison isn't case-sensitive
var filterSQL = "FULLADDRESS = '" + addresserStreetName + "'";
var matches = Filter(masterStreetName, '@filterSQL');
// 5. Logic: Return true if a match is found, false (with message) if not
if (Count(matches) > 0) {
return true;
} else {
return {
"errorMessage": "The address " + addresserStreetName + " does not exist in the master Street table."
MikeMillerGIS
Esri Frequent Contributor
Try this.  Also, when posting code, please use a code samples(Javascript works good for arcade).  Makes it much easier to read
if (IsEmpty($feature.FullStreetName))
	return true;
var masterStreetName = FeatureSetByName($datastore, 'vwAddresserData_v2', ["FULLADDRESS"], false);
var matches = Filter(masterStreetName,  "UPPER(FULLADDRESS) = @addresserStreetName");
	return true;
return {"errorMessage": "The address " + addresserStreetName + " does not exist in the master Street table."};
SarahWright
Thanks for the suggestion, I am now getting the below error.
Edit operation failed.
Failed to evaluate Arcade expression. [
Rule name: Invalid Street Name,
Triggering event: Update,
Class name: L0addresserData,
GlobalID: {1986C779-DA03-40F1-9FF9-60E436BF5926},
Error number: 1001,
Error message: Street Name is not in the master Street Name table.,
Arcade error: Table not found {F373DE5C-427D-466E-92A5-5988CFD4D5CA},
Script line: 7]
MikeMillerGIS
I do not know, I do not have access to the data so very hard to tell.  Can you verify the name of the master street name table?  Does you street have a street name of "Street Name"
SarahWright
This part of the error is returned from the error statement I created for the error number.
Error number: 1001,
It should not be looking for street name. That is not in the code.
It is very hard to tell. Do you know of a better way to troubleshoot the arcade expression? I have tried so many code variations at this point.
MikeMillerGIS
Do you happen to have any other attribute rules?  The error message does not match the code above.
SarahWright
Here is the configuration to my rule. There are no other rules with this error message.
SarahWright
The table name is slightly different in my picture. Another variation I tried to see if it would connect to another table.
MikeMillerGIS
Ok, That helps.  The error is that the FeatureSetByName cannot find table.  Can you move it all to a file geodatabase for testing to ensure the rule works?  That would help eliminate variables with enterprise databases and permissions.
SarahWright
Hi, thanks for your help on this. Moving the data into GDB and editing returned the expected results. My goal is to be able to use this in a editing web application. I am not sure what I was doing wrong. Any insight on getting this into our web application is greatly appreciated.
I am working on this in our dev ArcGIS Enterprise environment 11.5. Using enterprise gdb version 11.5 and ArcGIS pro 3.5.
Thanks
