Copying an attribute from multiple point feature classes to one line feature class using attribute rules.
1708
05-27-2022 10:13 AM
TravysBaker
Hello all,
After using this excellent video on copying attributes to lines  ( https://www.youtube.com/watch?v=ueckrlhto0Q ) I've automated a large portion of my companies utility asset id process within the map, which is great. I started running to problems with adding multiple point feature classes into this code in order to account for pipes (such as pressurized mains) that could have their start node at either a manhole or a pump, or in a water system the main could start/end at a fitting, a valve, a hydrant, or any other number of features.
In order to account for this I tried to add multiple variables to the original code so I can check different feature classes but that didn't work for me as it seems like Arcade doesn't appreciate having multiple feature geometries in one rule. Any help on this would be great!
Heres upper manhole code:
var g = Geometry($feature);
var fromManholeGeometry = g.paths[0][0];
var Manhole = FeatureSetByName($datastore, "ssManhole", ["facilityid"], false);
var fromManhole = First(Intersects(Manhole, fromManholeGeometry) )
if (fromManhole == null) return "No UPMH";
return fromManhole.facilityid;
Downstream manhole
//the '-1' grabs the last segment and last vertex of a line.
var toManholeGeometry = g.paths[-1][-1];
var toManhole = First(Intersects(Manhole, toManholeGeometry )  )
if (toManhole == null) return "No DNMH";
return toManhole.facilityid;
And again, any help would be much appreciated!
Learn how attribute rules can be used to automate attribution and copy attributes from one feature class to another. Download the sample project and data used in this video: http://ow.ly/W3Ea50B5Mnj For more information, please visit: http://ow.ly/4lrT50ANueJ ...
JohannesLindner
Something like this?
var fromPoint= g.paths[0][0]
// test manholes
var fromManhole = First(Intersects(Manhole, fromPoint))
if(fromManHole != null) { return fromManhole.facilityid }
// test pumps
var Pumps = FeatureSetByName(...)
var fromPump = First(Intersects(Pumps, fromPoint))
if(fromPump != null) { return fromPump.facilityid }
// test fitting
// default return value
return "no intersecting points found"
Have a great day!
Johannes
JohannesLindner
// test manholes
// test pumps
// test fitting
Have a great day!
Johannes
TravysBaker
Thats great, thank you so much!
