Attribute rule for maintaining many-to-many relationships
594
03-20-2026 05:39 AM
CarstenAndersson
I have two polygon feature classes, Municipality and District. There is a many-to-many relationship between the two, and therefore an intermediate table called Municipality_District_Rel. The relationships are automatically handled with attribute rules, based on a municipality must overlap a district with 80% or more for them to be related. And if a municipality cover less than 80% percent, the relationship has to be deleted.
The Arcade expression is:
// Arrays to store edits
var edits = [];
var adds = [];
var deletes = [];
// Get all District features
var allDistricts = FeatureSetByName($datastore, "District");
// Find District features that intersect this Municipality feature
var intersectingDistricts = Intersects(allDistricts, $feature);
// Determine which District features that this Municipality overlaps with 80% or more
var overlappingDistrictGlobalIds = [];
for (var district in intersectingDistricts) {
    var districtGeometry = Geometry(district);
    var districtArea = Area(districtGeometry);
    var intersectionGeometry = Intersection(Geometry($feature), districtGeometry);
    var intersectionArea = Area(intersectionGeometry);
    if ((intersectionArea / districtArea) >= 0.8) {
        // This district overlaps, so store the GlobalID for it
        Push(overlappingDistrictGlobalIds, district.GlobalID);
// Determine which relationships to add (new District features that overlaps with at least 80%)
var relatedDistricts = FeatureSetByRelationshipName($feature, "Municipality_District_Rel", ["GlobalID"]);
for (var index in overlappingDistrictGlobalIds) {
    var districtGlobalId = overlappingDistrictGlobalIds[index];
    Console(districtGlobalId);
    var relatedDistrict = First(Filter(relatedDistricts, "GlobalID = '" + districtGlobalId + "'"));
    if (relatedDistrict == null) {
        // A relationship didn't exist, so add it
        Push(adds, {
            'attributes': {
                'Municipality_GlobalID': $feature.GlobalID,
                'District_GlobalID': districtGlobalId
// Get existing relationships between Municipality and District features
var allRelationships = FeatureSetByName($datastore, "Municipality_District_Rel", ["*"]);
var relationships = Filter(allRelationships, "Municipality_GlobalID = '" + $feature.GlobalID + "'");
// Determine which relationships to delete (no longer overlapping with at least 80%)
for (var relationship in relationships) {
	if (!Includes(overlappingDistrictGlobalIds, relationship.District_GlobalID)) {
		// No longer overlapping enough, so delete the relationship
		Push(deletes, {'GlobalID': relationship.GlobalID});
// Return edits dictionary if there are changes to the relatio
if (Count(adds) > 0 || Count(deletes) > 0) {
    Push(edits, {
        'className': "Municipality_District_Rel",
        'adds': adds,
        'deletes': deletes
    return {'edit': edits};
When I click Analyze I get:
But when I try to save the attribute rule I get this:
What am I doing wrong?
MikeMillerGIS
Esri Frequent Contributor
Try this, my only guess is that adds or deletes is an empty array and maybe that is causing an issue
var edits = [];
var adds = [];
var deletes = [];
    var relatedDistrict = First(Filter(relatedDistricts, "GlobalID = @districtGlobalId"));
        Push(adds, {
            'attributes': {
if (Count(adds) == 0 && Count(deletes) == 0) {
    return;
var edit_payload =  {
if (Count(adds)){
    edit_payload['adds'] = adds
if (Count(deletes)){
    edit_payload['deletes'] = deletes
Push(edits, edit_payload);
return {
    'edit': edits
CarstenAndersson
Thanks Mike,
but unfortunately I get the same error. My initial though was a version issue. I am using ArcGIS Pro 3.3, but I get the same error message on ArcGIS 3.5.
The line that causes the error is: var allRelationships = FeatureSetByName($datastore, "Municipality_District_Rel", ["*"]);
But, it's the only way I can think of to delete the existing relationships.
Could this be a bug?
MikeMillerGIS
Could be, I never tried to work with a M:N in arcade.
