Attribute rule arcade statement
4325
11
08-27-2024 01:33 PM
EricBregant2
Hello! I am working on an attribute rule that will concatenate 6 fields that make up a street address to create a full address. The problem is that 2 of the fields are not always populated with a value. They will either be null or empty.
In the image below, you can see my 6 fields (ST_NUM, DIRPRE, FEANME, FEATYP, DIRSUF and Unit (LV_APT)
If I do a simple concatenate of those fields, the result will leave spaces at the end of the full address. I know this is because of there not always being a value in DIRSUF or LV_APT.
I have been working on the below code, but I know I am missing some parts. Any ideas or anyone know a better way?
// List the fields to combine
var parts = [$feature.ST_NUM, $feature.DIRPRE, $feature.FEANME, $feature.FEATYP, $feature.DIRSUF, $feature.LV_APT];
// Loop through the address parts, if not null or empty add them to a new array
var filteredparts = [];
for (var i in parts) {
    var value = parts[i];
    if (IsEmpty(value)) continue;
    filteredparts[Count(filteredparts)] = value
// Concatenate with a space
return Concatenate(filteredparts, " ");
EricBregant2
var parts = [$feature.ST_NUM, $feature.DIRPRE, $feature.FEANME, $feature.FEATYP, $feature.LV_APT];
// Function to check if a value is null or empty
function IsNullOrEmpty(value) {
return value == null || value == "";
// Add '#' before LV_APT if it's not null or empty
if (i == 4 && !IsNullOrEmpty(value)) {
value = "#" + value;
if (IsNullOrEmpty(value)) continue;
Push(filteredparts, value); // Use Push to add elements
var finaladdress = Concatenate(filteredparts, " ");
return finaladdress;
Brian_McLeer
MVP Regular Contributor
I think you have to add the "" function to check for if a part is empty.
    filteredparts[Count(filteredparts)] = value;
EricBregant2
Thanks @Brian_McLeer
EricBregant2
I found this as well
var fullName
if(IsEmpty($feature.ST_NUM)==false){
fullName += $feature.ST_NUM + " "
if(IsEmpty($feature.DIRPRE)==false){
fullName += $feature.DIRPRE + " "
if(IsEmpty($feature.FEANME)==false){
fullName += $feature.FEANME + " "
if(IsEmpty($feature.FEATYP)==false){
fullName += $feature.FEATYP + " "
if(IsEmpty($feature.DIRSUF)==false){
fullName += $feature.DIRSUF + " "
if(IsEmpty($feature.LV_APT)==false){
fullName += $feature.LV_APT + " "
return fullName
MikeMillerGIS
Esri Frequent Contributor
Here is how we do it
function not_empty(x) {
  return !IsEmpty(x);
return Concatenate(Filter(['a', 'b', '', null,'c'], not_empty), '-');
returns
 "a-b-c"
MikeMillerGIS
If you want to handle "  ", then change not_empty to
  if (TypeOf(x) == 'String'){
    x = Trim(x)
  return !IsEmpty(x);
TedHoward2
You may need to adapt your code filter out strings with spaces.
IsEmpty(null) // true
IsEmpty("") // true
IsEmpty(" ") // false
EricBregant2
I got the below code to do everything I want except to add an "#" before the unit number ($feature.LV_APT).
Any ideas?
EricBregant2
