Make the attribute rules window less jumpy
1197
02-28-2022 05:03 PM
Status: Closed
Bud
Legendary Contributor
Regarding the Attribute Rules —> New Rule window:
When I'm creating a new rule, I scroll down to enable the triggers (Insert and Update):
When I click the Insert checkbox or Update checkbox, the window quickly scrolls to the top — without checking the checkbox. So I need to go back down and try again.
That happens for each checkbox I need to enable.
It's aggravating when that happens.
Would ESRI be able to improve that window so that it's less jumpy?
Edit:
This happens in other scenarios too. If I try to disable an attribute rule, the window jumps to the top and the checkbox doesn't get checked.
Tags (1)
2 Comments
Bud
ArcGIS Pro Version 2.9.32739 (including patch #1).
Windows 10
SSWoodward
Status changed to: Closed
Thanks for the idea @Bud
This sounds very frustrating. I am not seeing this behavior in any of our recent releases.  Are there any conditions that you can identify that may bay causing this bug? If it is reproducible I'd like to be able to open a bug for it.
Since this post qualifies as a bug, and does not meet the requirements of an Idea, it will be closed.
