Arcade within() actually queries the feature it is within
7884
16
09-06-2023 01:45 PM
JonathanMcDowell1
I am using the within() function to query an underlying feature class. Then calculating fields based on the values pulled from the within(). If the feature is an odd shape it will return nothing or the wrong value. I am using this syntax, within( querylayer   ,centroid($feature)). Sometimes the centroid is outside of the feature.
In the image below, the within function is using the red point to query the 31E33AD polygon. I need the function to query the 31E33 polygon using the green point. If I remove the centroid function, within() returns nothing.
Red is the centroid used by the within() function.Red is the centroid used by the within() function.
My suggestion is to create a function that uses a center point within the selected feature. Or fix the centroid function to place the point within the feature.
16 Comments
DeanAnderson2
The following code uses intersect and gets the largest intersecting polygon to make the assignment. It appears to be an OK workaround.
// Get map number from mapindex polygon layer using interesect
// Do interesect and county features.
var fsMapIndex = FeatureSetByName($datastore,"MapIndex",["MapNumber","ORMapNum","County"])
var fsIntersectMap = Intersects(fsMapIndex,$feature)
var MapIndex = first(fsIntersectMap)
var intcount = Count(fsIntersectMap)
// If no features return error
if (MapIndex == null) return {"errorMessage": "No Map Index Feature Found"}
if (MapIndex.Mapnumber == null) return {"errorMessage": "MapNumber is empty"}
// If count is one then return values
if (intcount == 1) return {
"result": {
"attributes" :{
"MapNumber" : MapIndex.MapNumber,
"ORMapNum" : MapIndex.ORMAPNum,
"County" : MapIndex.County
// if county > 1 (taxlot overlaps mapindex) then
// loop thru and keep intersect with largest area.
else {
var MapNumber = " "
var ORMAPNum = " "
var County = 0
var intersectarea = 0
for (var f in fsIntersectMap){
var newintersectarea = Area(Intersection($feature,f))
if (newintersectarea > intersectarea){
var MapNumber = f.MapNumber
var ORMAPNum = f.ORMAPNum
var County = f.County
intersectarea = newintersectarea}
return {
"result": {
"attributes" :{
"MapNumber" : MapNumber,
"ORMapNum" : ORMAPNum,
"County" : County
MikeMillerGIS
Do not call Count and First on the FeatureSet. This will cause unnecessary database queries. Just loop over the featureset and handle if the results are empty(none) and get the largest.
DeanAnderson2
Thanks - that makes sense.  Built this off of old code and was just pretty focused on making the area check work.
DeanAnderson2
Better code - Again Thanks !
if (fsIntersectMap == null) return {"errorMessage": "No Map Index Feature Found"}
var MapNumber = "None"
var ORMAPNum = "None"
var County = 99
return {
"result": {
"attributes" :{
"County" : County
MikeMillerGIS
Looking good, just a little clean up
No reason to check the FS for null.  Think of a FS as a database cursor.  Just cycle over it and check if the results are null afterwards
Declare your variables outside the loop
var fsMapIndex = FeatureSetByName($datastore, "MapIndex", ["MapNumber", "ORMapNum", "County"])
var fsIntersectMap = Intersects(fsMapIndex, $feature)
var MapNumber = null;
var ORMAPNum = null;
var County = null;
for (var f in fsIntersectMap) {
    newintersectarea = Area(Intersection($feature, f))
    if (newintersectarea > intersectarea) {
        County = f.County
if (MapNumber == null) {
    return {
return {
    "result": {
        "attributes": {
            "MapNumber": MapNumber,
            "ORMapNum": ORMAPNum,
            "County": County
DeanAnderson2
Thanks!  Always good to have somebody cleanup my code.  Much appreciated.
