Add Extra geometry functions in Arcade
1164
01-29-2023 11:00 AM
Status: Closed
Jan_Creupelandt
In Arcade, you can already rotate a geometry. There is also an offset function, but this translates the geometry only in horizontal direction (left or right).
I suggest to add additional Geometry functions:
  • Move : move a geometry by defining a startpoint and an endpoint
  • Scale : scale a geometry by defining a basepoint and a scale factor
  • Translate : reposition a geometry by defining 2 pair of points -> this will move, rotate and scale at the same time (also known as an affine transformation)
1 Comment
KoryKramer
Status changed to: Closed
This is a duplicate of https://community.esri.com/t5/arcgis-pro-ideas/add-extra-geometry-functions-in-arcade/idi-p/1251779. Users interested in this functionality, please add kudos to the existing idea and comments including your use case. Thank you.
