xy event will not display points in reader.
943
10-28-2010 06:34 AM
jessebelcher
Ok so i made a xy event layer in arc-map. It shows my points based off of a field if it has a 1 the point will display if a 0 then no point. All works well in arc-map.  I am using an access table as my reference data.
I publish this mxd to arc reader and the points show up until i change the reference table. The data is there but the points dont display. Is arc-reader locking down the table?
I am trying to used arc-reader in laptops. We want to send them a text file run a macro to update access table and refresh arc-reader. Points will then show them where the problems are.
