Reader - Can't get Joined data to publish
1702
03-23-2012 12:36 PM
JimCreighton
I know I've done this is the past . . . have an mxd with a layer thematically displaying based on values in a spreadsheet to which it's been joined.  When I publish, the joined fields are gone, as well as the rendering.  Just applied SP4 to both ArcGIS Desktop (View) and ArcReader.  Any ideas?  Here's my data:  http://www.arcgis.com/home/item.html?id=2b434536ec9f4ec5a67f02509ea2c36f
JuanLuera
Jim,
In doing some testing with the information provided, I also have 10.0.4 (ArcMap) and I was unable to reproduce the issue you are seeing. I would like to work with you on this issue, so if you would submit a webform and add my name. We can have a incident created and then trouble shoot this issue together. Gracias!
Support Service
1-888-377-4575
http://support.esri.com/en/webform/s...275/chat/false
