Publishing Map units
2290
10-17-2013 04:50 AM
ErikBlake
Hello. We are currently using ArcReader 10 for publishing maps. When I publish my map (mxd) using feet as my map units that gets carried over to my published document. However if I set my map units to Decimal degrees. (which is the one that I want) and publish the map the map units in ArcReader display as degrees minutes seconds. Was wondering if anybody had any ideas on how to get ArcReader to display my map units as decimal degrees like the mxd. instead of the degrees minutes seconds.
Erik
