On-the-fly coordinate transformations
1829
03-14-2011 02:10 AM
DavidRushton
Hello All,
I am considering starting to produce published maps for ArcReader, and was wondering if (and how easily) it supports the on-the-fly coordinate transformation that ArcMap performs when you display datasets with different geodetics in one map.
Any advice / previous experience greatly appreciated.
David
JuanLuera
Hola David,
If you add your data with different spatial reference system, ArcMap will project this on-the-fly and properly display. When you create your pmf file, this will carry over and be seen within ArcReader when you open the pmf file. Gracias, David!
