ArcReaderControl delete markup
2098
09-19-2011 06:06 AM
darkogeorgievski1
Is it possible to delete all drawn line with some function? Users don't want to select erase and the erasing line by line.
Darko
JamiWangler
Have you ever found out how to delete all markups?
I am having an issue with ArcReader markups as well.
When using them a client gets an error message that shuts down the project. When it is opened again, the markups are still there, it is like they cannot be deleted.
Also the Reader project is a shortcut on their desktop, not sure if this would be causing the problem?
AdamTill
I worked with the ArcReader .net control, and the only way I ever found to remove all markups was to programmatically remove the *.pmfink file that's created when the markup is saved. With that removed, and the pmf is reloaded, then the markup is gone.
