ArcReaderContol 10 - Use in Visual Basic 6
3875
08-15-2010 11:12 PM
AntonSeiler
can ArcReaderControl 10 be used in Visual Basic 6?
My very larg Visual Basic 6 program works fine with ArcReaderControl 9, but crashes at 10.
Has anyone a sample for Visual Basic 6?
Anton
AntonSeiler
now it works!!
You have to reference to ESRI.ArcGIS.Version und have to do some license-check.
JosefGasch
can you provide some sample code or give more detailed advice?
Thank you in advance
Josef
JasonMiller
Does anyone have any advice on this problem... I've got a fairly large project as well that is written in VB6 and uses the ArcReaderControl...  If I run the program inside of Visual Basic 6 IDE it runs fine, but when I compile it and run it, it fails (Error 7 - Out of Memory...)
Thanks!
Jason
