ArcReader:  Accessing one-to-many relate
3083
12-27-2010 09:17 AM
JimFritz
I have set up a one-to-many relate prior to publishing an ArcReader .pmf.  Is there any way to view the "many" features associated with points (via the relate performed in ArcMap) in the shapefile using the Identify Tool, for example?
Thanks in advance!
J Fritz
JuanLuera
Hola J Fritz,
In looking into this question for you and testing this, I would say there would not be a way to view the �??many�?� features associated with the points. Since this is a reader/viewer of the data which has been published, and not ArcMap where you would be able to see the associated features. Within ArcMap you would see them since you are working and have the ability to see the actual data, not an option within a reader. I am including a few screen shots, where I identified the points in both and this is the only results you will be able to see. Gracias, J Fritz!
DanEvans
Joins and Relates as set through ArcMap in the layer properties are not published to ArcReader.
If you want to retain joins when published you have to export the feature class to create a new feature class with the join already in place.
If you use geodatabases and set up relationship classes, these will be published intact.
So if you have ArcEditor or above it is possible to access the related "many" data through ArcReader, if you set up the relate as a relationship class.
Hope that helps,
Dan
