10 Final: Sorting layers in TOC and changing symbology
1232
06-22-2010 01:22 PM
ArcGISUser
I should have posted this on the forums (because I had the links or paragraph copied), but I contacted support directly in this case. So in beta 10, I was reading the help and it said that when using pmfs, you can do two things: 1) Sort the layers in your table of contents, and 2) Change the symbology of your layers.  I contacted support because I read this in the 10 help document, but I was not able to do this.  A support analyst got back to me and said that it was beta software and that this functionality would be available at final release.  Using 10 final publisher and 10 final ArcReader, I see that this was left out and the help doc changed to exclude that info.  😞 Why is that?  This would have been great to have at 10. 😞
