Way to edit overlapping point features in ArcPad?
733
04-11-2013 10:43 AM
MichaelBishopp
I have overlapping points in my ArcPad project that I want to be able to edit in ArcPad.  Is there a way to get at overlapping points through the attribute editor?  It seems like the only option I have currently is to edit the top point--which is not what I want.  Do I have to "spread" the points in ArcMap before exporting the ArcPad project?
Thanks beforehand,
Michael
Tags (3)
GarethWalters
Hi Michael,
The first approach I would suggest is to use the FIND tool or even a QUERY PAGE to select the correct feature and then you can open the form of the selected point.
As as first cut, I hope this helps.
Cheers,
Gareth
